Old 06-10-2016, 04:11 AM   #2
CHRISP357
CHRISP357's Avatar
Set # 3 - $100 shipped (Continental US Only)
This clear set has the outer lenses removed.
This was an early experiment with clear coating that did not go well, so they will need to be sanded down and re-finished.
The inner reflector bowl lenses have burn marks and will need to be replaced or removed.
No bulbs included and the insulation on all the wiring is cracked and missing (dry rot, will need to be replaced).
The passenger side is missing one the rear cover catches, but it still closes/seals fine (see pic).
These would be a good project for someone that wants to do an HID retrofit.
No outer fender gaskets.
Can you put these clear covers on my headlights?
CHRISP357 is offline   Reply With Quote
