Old 06-08-2016, 09:35 AM   #10
Need_for_speed
Some years back, Porsche released an updated spring and piston for the oil pump, with a bevel on the top edge of the piston and a slightly stronger spring which improve the oil pressure slightly, particularly at low RPM's when hot. Parts are about $20, and it is a 5 min. swap when the car is in the air. Part numbers are 997-107-125-01 for the spring, 996-107-127-53 for the piston, and 996-107-123-50 for the crush washer.
The front brake ducts are a GT car item, and much bigger than factory for improved brake cooling, particularly at the track. Funny bit is that again they are less than $20 for the pair; part numbers are 997-341-483-92, and 997-341-484-92 (left and right). As the old units pop right out, these larger units are another 5 min. project.
JFP, thanks a million! I'll be doing both soon. Nothing better than cheap upgrades that actually work.
Need_for_speed is offline   Reply With Quote
