I was about to say the same thing You have a 5 chain engine with a moveable set of pads between each pair of cams in the head The cam chain pads have been redesigned to last longer and are quite cheap like $15 per head . They require the cam covers be removed along with the cams and then retimed after installing the new pads. I,ve read you can do it with the engine in place but it would be a bear of a job, much easier with the engine out. The cel will trip when deviation gets to about 8 deg.
