Old 06-07-2016, 01:04 PM   #2
Heiko
Heiko's Avatar
If the cam deviations are out past +/- 6 degrees you need to get the cam chain pads replaced that run between the cams. Its a bit of job to get these done with the engine in the car but much easier with the engine out. If you have no damage so far and it hasn't kicked a code (it probably will soon) but I would get it done before the chain goes through the last remaining bits of nylon and chews up the cam adjuster assembly (that could get costly)
H
Previously owned:
