Old 06-07-2016, 06:32 AM   #467
JEhunter
John - I did a little research on the GM V6 (Camaro) motor after our call today.
2012-2015 Camaro V6. 'LFX' 3.6L aluminum motor/aluminum heads DOHC. It makes 323 HP @ 7200 rpm and 278 Lb-ft @ 4800 rpm. I couldn't find the weight on the motor but my guess is that it's lighter than the stock Boxster 3.2L.
I'll see if I can find some dimensions on the V8 so we can compare them to the LS. This could be pretty sweet build
I found the weight. GM claims 345 Lbs and Porsche show the boxster motor weight at 399 lbs. So, the LFX looks to be about 54 pounds less...
JEhunter is offline   Reply With Quote
