Old 06-05-2016, 03:40 PM   #27
SilverSSS
From your previous description of the metal bits in your filter, yours are hardly microscopic. Suggest your re-read this: Bearing already failing? – IMS Retrofit
We have seen several people do what you are about to attempt; to date, very very few have ever been successful, with most suffering failure in only a relatively few miles after retrofitting. Its your car and your money, so proceed however you please, just be conscious of the risks (financial and time) you are entertaining.
Good luck.
OK, Thanks. I'm sure you've forgotten way more about this issue, and porsches in general, then I'll ever know. And that's fine, because i really just want to drive the car. That being said, the engine has been going for 54k miles thus far. I would be very surprised if it suddenly blew up, just because i improved the bearing and installed a magnetic drain plug, no bypass fliter, and magnetic filter screen. But thank you for pointing out the risks, because of it, i changed the oil, and ordered afore mentioned parts from LN. Only time will tell what happens, but i intend to drive it and not worry. On balance, this works for me. Thank you for taking the time to advice me on this issue. Chris.
SilverSSS is offline   Reply With Quote
