Hi Markus.
Yes, it's a 5-speed. New front motor mount, new shift fork, system was properly bled, clutch works perfectly. No issues other than 1st gear can't be engaged with either the engine on or off.
My linkage is the same as the one pictured.
I wonder if the cables are reversed? I didn't even consider this since the car shifts well with the exception of first gear. I even labelled the cabes before I took them off, but maybe I goofed.
I'll reverse them this evening and report back.
Thanks.
