Old 06-04-2016, 01:35 PM   #12
JFP in PA
Originally Posted by Flavor 987S View Post
Only use the DT40 if you do the BR30 flush (about 200-400 miles) first.
The breaking in oil flush is the optimal approach, but it is not really critical. A lot of people simply do a good drain and refill with the DT40. Once you get past an oil change or two, you will be in the same position as if you did the flush.
