Old 06-04-2016, 10:40 AM   #2
JFP in PA
Originally Posted by Chuck W. View Post
I have owned my Boxster since new. It has the original IMS baring. However, on July 2, 2008, at 16,452 miles, the RMS was upgraded.
The invoice states, "R&I Exhaust, R&I Transmission, R&I Clutch and Flywheel, R&R Rear Mail Seal, R&I Tensioners, R&R Intermediate Shaft Flange Seal, Clean Oil Residue From Trans and Engine."
The total bill was $2223.52 and listed the following parts;
1 - 997.101.212.00 Shaft Sealing RI
1 - 996.105.112.01 Rubber Gasket
4 - 999.385.004.01 Torx Screws 3x35
3 - 900.385.275.09 Torx Screw 5x29
8 - 999.073.092.09 Screw 10x50
Reading other posting it appears that you can tell what baring your Boxster has by looking at the IMS flange seal. Do any of the part numbers above appear to be the IMS flange seal that they replaced during this service? And if so, can you tell if it was for a single or dual baring? TIA.
Not the flange seal, but by looking at the metal flange itself (they are noticeably different). Both the single and dual row IMS flanges use the exact same seal.
