Hello Ton,
yes this is the mount for the front engine mount. But these 4 are bolts and screws. So if you're lucky the bolts come out with the screws.
Don't forget to support the engine while doing this. You an do this from the top or from the bottom. But if you want to remove the complete intake system i would recommend to support from the bottom.
Regards, Markus
