Old 06-03-2016, 04:58 AM   #21
JFP in PA
Originally Posted by SilverSSS View Post
911monty,, those tiny dots distributed randomly around the inside of the metal cylinder your holding right? That's about what I'm seeing> Thank You So much, i feel better, seemed normal to me. you have to put eyes on it, and that's not always possible, T/Y.
What he is showing you is the ultra fine ferrous grit that normally passes right through your oil filter and continues to collect and circulate in your oil unless you:
  • Add a "full flow" (read no bypass) spin on oil filter
  • Use a FilterMag on the spin on housing to trap the ferrous grit and remove it with each filter change
