Originally Posted by JRL
Hey JJ did Steve have a good solution for your axle problems.
Did you get the video links and pictures I sent you?
Hey Randy,
Yes I did, very cool!
I spoke with Steve and while I'm sure what he does will improve the situation, I'm not sure i'll be 100% happy with it. Basically supplying factory axles which he would then be "race prepping" the outer CV joint. That is all he wants to do which is basically changing to a chromoly cage and put in "good" axle grease. Not sure that is going to solve my problems, but rather buy a bit more time.
A big part of my concern is the wear on the outer CV housing as this is causing me to wear out the axles in about 3,000 miles or less. Steve basically said I could expect to get 3x more life out of them which is roughly 9,000 miles, then I have to find a new set of factory axles, rinse and repeat.
I am going to talk to fabrication shop near by and throw some ideas at them to see if I can come up with a better solution. By better I mean longer lasting, stronger and easily replaceable or able to be rebuilt by me rather then having to send them back off to Colorado or wherever.
I am also going to talk with them about producing V6/V8 conversion parts. I've been looking around lately and am thinking that the newer 3.6L V6 from the 2012+ Camaro could be a good replacement for bad 986 motors. They make 323 HP, are pretty compact so hopefully the conversion could be done without any cutting of the existing structure and from what I can see used motors are fairly cheap and plentiful. Just be a matter of the full integration with wiring etc. which means you likely need a throttle pedal etc. and I don't think Chevy makes a plug and play type setup for the V6 motors like they do the V8s. I'll start another thread on that once I gather a bit more info.
J
