Old 06-01-2016, 03:15 PM   #12
rastta
rastta's Avatar
What did you decide on for bump steer adjustments? Did you use a default amount of shims in the Stromski kit? It is hard to tell from this pic.
Your OEM brake ducts look different, like a piece is missing from the front. is that because you have the hose based brake ducts?
Yes - went with the max on the Stromski as a start. The bolt is long enough to add more if necessary.
The OEM's have been cut in several areas for clearance - but it's as it came when I bought it. I should have taken pictures of the pieces that attach to the hub carrier - they bolt on where the brake line does and direct air into the inside portion of the rotor. They attach to the hose that goes to hand made ducts that are attached to the front of the car directly behind the front bumper's inner slot openings next to the center opening. The previous owner did a bunch of handmade pieces on the car. I thought I had pics of those - but i'll look for them.
rastta is offline   Reply With Quote
