Old 06-01-2016, 09:54 AM   #10
rastta
rastta's Avatar
Finished the install of the inner and outer tie rods. While I was in there - I also put in new swaybar bushes and added new ones to the rear as well. Rebuilt the other front caliper (did one a few weeks ago) and re-did the brake hoses from the front ducts to the wheel hubs. The Stromski parts are top notch and a bit different from the design originally pictured - which is a good thing. Now I just need an alignment and brake fluid bleed. Bought a new tie rod boot kit but it turned out to be the wrong size - the diameter of the boot was too small to fit on the steering rack. Not sure why. Is the S rack bigger than the regular Boxster rack or is it a matter of different racks for different Vin's. If anyone needs a set of boots - I'll sell em for $20.
rastta is offline   Reply With Quote
