Thread: coolant leak?
Old 05-31-2016, 08:20 AM   #23
RandallNeighbour
The water pump is easier to remove from the bottom by removing the front motor mount first, which should be swapped as well because the bushings wear out really fast. When I needed to swap out my front motor mount, I replaced my water pump even though it wasn't leaking... These aren't a bad pair to replace whenever the other one needs it.
