Old 05-30-2016, 03:50 PM   #100
GTsilber
No. I'm sure just a bit was getting past. Maybe just steam vapors. Check the fluid level when warm and level. There's an indicator on the tank. If WP was failing or stat stuck closed, you'd have over heating too. Remember, that tank has been known to fail commonly.
Thanks Timco, yeah I've heard about how common the tank failures are, luckily the tank itself seems to be ok.
Now that one issue has been resolved can someone help me narrow down my AC issues - here's a list of signs/symptoms:
- AC blows hot air only
- HVAC unit appears to be working correctly, snowflake is visible on display, tested system on Lo and fan on high
- replaced fuse E7 and D6
- the AC is blowing air, the blend doors open (can hear them)
- hissing noise coming from the AC vent as well as from the condenser pipes in the frunk (sounds like an air leak) but I can't find source
- both condenser pipes are hot to the touch
- system holds pressure at 25, recharged the system with 30oz r314a but still no cold air
At this point I'm thinking it's the compressor - how can I verify/test? Anything else I can lookout for that will help narrow down the checklist?
GTsilber is offline   Reply With Quote
