Your bottom pic shows liquid over towards the thermostat housing, which is the curved pipe thing with 2 bolts and a larger hose clamp and hose going to it. This area would indicate a water pump leak which is also bad. The water pump has a hole in it and this is where I would expect to see water appear.
Water pump is behind the pass seat and you need small hands!
This is how you get small hands to do your work!!
Allie does all her own work on her cars; 944, 911 and Boxster. The small hands pay off for this job.
