Thread: coolant leak?
Old 05-29-2016, 08:02 AM   #1
rexcramer
1997 Tip, 2018 Macan
rexcramer's Avatar
Have you pulled both the oil and the coolant caps off yet and looked under the cover?
Your purge valve may be leaking also. This valve is hidden under a flat plastic plate that cannot be seen until you pull both caps and the plate off first.
Look at the second pic from jcslocum. The green circle is the purge valve.
