Think of trying to snap a pencil in half. More force is required to break it the closer together you move your hands. Same with the sway bar. More force is required to contort it as you move the mounting location inwards so it functions as a stiffer bar. You can actually have different settings on each side of the bar if you fine you need to fine tune the stiffness more precisely.
