Old 05-28-2016, 07:03 PM   #20
JayG
On the slippery slope
JayG's Avatar
Originally Posted by boxxster View Post
How were the old shims when you took them off? Did they need to be changed or did you just change them because you had already purchased the new ones?
My shims were fine, but since I put in the 987 part, it is supposed to use the newer shims which are a few mm thicker. My feeling was I would not be changing the mount for a long time and since I saved a bunch of $$ but replacing the insert, might as well used the proper shims.
All in all, I spent less including the stupidly expensive shims saving around 35% of the cost of the full replacement part. And didn't have a piece of scrap aluminum left over
2004 996 Targa Tip
Instructor - San Diego region
