P0138 says the O2 sensor behind the cat on bank 1 is shorted.
P0410 and 0411 says that the SAI pump is not working. This requires further investigation to determine if it is the pump, wiring, fuse, relay, or the change over valve.
P1124 and 1126 says that your fuel mixture is so lean on both banks that the DME cannot compensate. Usually an intake leak or fuel delivery issue.
