			As said you need to ID where the oil is dripping from:Plug or Filter canister
 You mentioned rubber 'O' ring in your oil!!
 **Did you put the new 'O' ring that came with the new filter on the filter canister???
 Hopefully you wiped everything clean so you can see what's the culprit
 Check torque on plug and I just hand tighten my filter canister so recheck yours is tight
				__________________2002 S - old school third pedal
 Seal Grey
