Walshie - the Pentosin ATF-1 that I posted a link for -IS- the OEM fluid. It's what came in your transmission originally.
There are one or two compatible fluids (with numeric designations that I can't remember - one is listed in the 101 projects book) but I would only use the original stuff in mine.
Be careful. I think there is another Pentosin fluid that looks similar (same color bottle) with a similar name, but it's the wrong stuff.
The back of the correct bottle will have a Porsche part number listed (999.917.547.00) in the Meets and Exceeds section. The bottle also says it's good for 120,000km. Don't believe it!
I'm not telling you to change your fluid. Just offering advice based on my experience if you should decide to do it. Factor that in with what you are hearing from others on the forum before making a decision.
2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
