Old 05-26-2016, 08:39 AM   #460
BoxsterLS376
Hello John,
i have a stupid question. The axle itself is fixed with a circlip at the transmission side and at the outer side you can also disconnect it (did it when changing my axle boots). Isn't it maybe possible just to change the axle itself and take the inner and outer parts as they are?
Regards, Markus
Part of the problem is the CV joint Markus, the stock joints are wearing out very fast, like within 3,000 miles the joints are worn enough to cause vibration while accelerating.
I am still in the discovery phase so if I can figure out a way to build a good axle setup then great, if not i'll just sell it as-is and let the next guy worry about it.
John or J.J. - But I answer to most anything~
*2000 Honda Accord 4DR V6 - 220K*
http://986forum.com/forums/show-tell-gallery/54328-boxsterls376-introduction-ls3-conversion.html
BoxsterLS376 is offline   Reply With Quote
