Old 05-26-2016, 12:07 AM   #11
Smallblock454
The only way to flush out the converter (without removing the transmission from the car) is repeated fill, run, and dump cycles until the draining fluid is clean.
OK, that is bad news. So you can only dilute the ATF. And if you have a volume of 9.5 litres and only get ould approx. 3.5 litres that is a never endng process.
Mercedes also had this lifetime filling ATs. In 2008 or 2009 they decided to bring back drainage bolts on the torque converters, because the lifetime didn't work and the cab drivers were really pissed by broken ATs. Hope the lifetime filling works better on Porsche AT.
Regards, Markus
Smallblock454 is online now   Reply With Quote
