Old 05-25-2016, 10:39 PM   #1
Cunningr
Cunningr's Avatar
Originally Posted by Myoung73 View Post
Yes change dash speakers first or at least at the same time as replacing head unit. About as simple as you can get and probably under $100 in cost. By far best bang for your buck as the originals are total crap paper and you might be disappointed with a new head unit with the crappy speakers. I did alpines using the existing speaker baskets about a month ago. So much better. My guess is you can bypass the amp just need to hook into the speaker wires in the frunk. I also bought the rear speaker kit (Suncoast) haven't installed that yet but soon hopefully. I have the Suncoast double din trim kit from the previous owner but am on the fence about undertaking replacing that mainly because I have and 03 which, like yours, has the MOST system. Good luck and have fun whatever you decide!
I am like you on the fence about double din on one hand would like nav function built in but i like the stock retro look. HU definately getting changed, as i want hands free and streaming capability.
Correction on the HAES amp power unless there were other units the power is 4 x 40 watts not 25. The change to the 996 cabrio 6 x 40 watt amp was cheap and easy. You can actually hear some bass from the doors. Albeit not a. Super high system but it sounds excellent. In my opinion 6 x 40 watt in such a small space is plenty, if all you want is good decent sound. A small underseat sub would be nice though for a bit more bump.
Last change the speakers in the dash, seriously even some $30 pioneers will sound better than whats in there, until you can get something better.
