Old 05-25-2016, 02:58 PM   #1
Luv2Box
Luv2Box's Avatar
That system, like many others, will not work on the Tip because it connects via the transmission cooler lines, which the Tiptronic lacks (it has an integrated oil to coolant heat exchanger that is part of the transmission, so the are no transmission fluid to cooler lines, only external engine coolant lines).
What is the method to flush the torque convertor and is it necessary when changing the fluid?
Luv2Box is offline   Reply With Quote
