Old 05-25-2016, 01:27 AM   #6
Smallblock454
Hello,
cylinder heads. From the part number the heads seems to be different – so there might be differences, so you should check that in very detail (even if the 986 parts number says 996 in the beginning):
986S - bank 1: 996 104 001 09
986S - bank 2: 996 104 002 09
996 - bank 1: 996 104 003 05
996 - bank 1: 996 104 004 05
Also the prior part numbers don't match.
It's pretty unusual that cylinder head gaskets break in this engines. Mostly it's a cracked cylinder – open deck design. If you have access to an endoscope camera you can check it with pulled sparks.
The 996 doesn't have a combined water / oil cooler. The oil cooler system is completely separated.
Regards, Markus
