Old 05-24-2016, 11:06 PM   #11
Mig
I finally got my Boxster running again! i bought it in Dec 2014. The clutch got so stiff a few weeks later and finally the slave cylinder blew in Jan 2015. I had a motor to rebuild on another car before I could finally start on the Boxster. The summer was hot so I didn't do too much on it. In the end I replaced the following:
- clutch
- flywheel
- IMS bearing
- RMS
- resealed oil pan
- shift fork, ball pin, spring
- output shaft seal
- tranny gear oil
- slave cylinder
- hydraulic fluid change
- spark plugs and apark plug tubes
- rear struts
- rear drop links
- AOS
I'm waiting for the rear bumper cover to come back from the paint shop before I can put the car back on the road, but I did take it for a drive up and down the street with the firewall and top engine cover off - loud and wonderful sounding!
Mig is offline   Reply With Quote
