Old 05-23-2016, 09:54 AM   #126
jdraupp
Originally Posted by tada View Post
I removed the vacuum hose for the brake booster and sealed over the opening with duct tape. Same results. Running on bank 1 only. So I have chased the vacuum leaks. The only thing I can think of now is to remove the fuel injectors and send them off for cleaning and flow matching. I may be wrong about the flooding of bank 2. It may just be too lean. The plugs have a slight smell of gas, but look brand new. So maybe I have three stuck injectors? The car did sit for months. I have tried running techron through them.
The only thing with the techron is if you can't get it to run it won't do you any good. It works by passing the fuel through the injectors. So it's possible I guess that if you have a stuck injector that the techron can't get there? Good luck, hoping it's this. You've tried all else.
