Old 05-19-2016, 02:03 PM   #10
Highrise
Your seat belt receptacle mounting hole may be a fair amount bigger than the bolt, if a sleeve/bushing didn't come with your Omix-ada seat belt receptacle adapter you would want to get something like SR s65 from here:
https://www.schrothracing.com/competition/hardware/bolt-in-hardware
This will allow your seat belt receptacle to pivot and will spread the load around, instead of concentrating it onto one contact point on the threads of your 7/16 bolt.
Since I'm using the factory bolt (7/16-20) to attach the buckle directly to the side mount/Omix-Ada backing plate (also 7/16-20), I'm hoping it should go together without any issues. That way I'm keeping it as close to the factory design as possible.
But I do see what you're saying about the belt being able to pivot as a way to spread out the load. Since the seat wont be changing positions, I'm planning on setting it and leaving it since that seems to be how the oem bracket is designed. Well, at least I've never really noticed any back-and-forth movement with the buckle attached to the factory seat frame.
I'll post updated pictures as soon as I dig into this a little more.
Highrise is offline   Reply With Quote
