Old 05-18-2016, 12:03 PM   #32
JFP in PA
Cool, so you connect the hose from the pressurized tank to the oil filter housing?
You can use a modified filter housing, but I prefer to use the oil pressure sender port, and the oil ports on the cylinder heads so that the filtration system is wet as well.
