Old 05-16-2016, 04:45 PM   #446
BoxsterLS376
Hello John,
well, 2.800 USD is a lot of money. The OEM 986S axles should be able to handle around 500 Nm in normal street use. But on the drag track that might be different, because of a different grip situation - less slip.
Also maybe it's good that the axles are the weak part, because if you always would need a new gearbox or differential this might be much more expensive journey.
Regards, Markus
Yeah from the research i'm doing the factory axles "should" be good for about 550HP, but considering I am trying to get the car tuned and will be making very close to that number I really need to find a better solution. The good news is that used gearboxes are fairly cheap so if that breaks I can get one for like $1200, cheaper then upgraded axles!
Oh yeah so the #1 company on the list for upgraded driveshafts quoted about $3500 for a custom set of axles. F-that. i'll break a few dozen more cheap ones for that price. UGH.
John or J.J. - But I answer to most anything~
*2000 Honda Accord 4DR V6 - 220K*
http://986forum.com/forums/show-tell-gallery/54328-boxsterls376-introduction-ls3-conversion.html
BoxsterLS376 is offline   Reply With Quote
