Old 05-16-2016, 10:51 AM   #2
rick3000
There Is No Substitute.
rick3000's Avatar
Is the bolt turning but not coming out?
The top two amplifier bolts go into rubber nuts that expand, and they tend to disintegrate over time or when being removed. If the bolt is just spinning in place and not coming out, you will have to pull the entire bolt and nut out, which will rip the rest of the rubber nut apart. When you reinstall you will want to replace the nut, PN: 999 500 078 00. I used an adjustable cresent wrench when I replaced my amp, the bolts should not be difficult to unscrew.
