Old 05-16-2016, 08:51 AM   #2
rexcramer
1997 Tip, 2018 Macan
rexcramer's Avatar
I have had the cables come off of the pulleys and wedge between the pulley and the frame. It sounds horrid. Don't use it or you will shred the cable. Search for the bike cable adjuster. It is a bit of a job but doable. You need torx bits for a couple of screws. Be careful if you have door airbags.
