Old 05-14-2016, 04:27 PM   #1
Pominoz
Pominoz's Avatar
Originally Posted by PaulE View Post
I've had some wheel wobble issues with my 18 inch Light Carrera wheels that are OEM and came with the car new, with what passes for roads here in the Northeast US. Nothing that couldn't be straightened, but a pain to deal with. I find checking the air pressure frequently and making sure they tires are up to the correct air pressure helps. But I also picked up a set of OEM 17 inch wheels and am mostly using those. I find the extra half inch of sidewall gives me a little extra protection from the crappy roads and potholes.
Ok, that's interesting. I keep the pressures correct, pretty important on a Porsche if you want to drive it like a Porsche When you look at the width of the rear wheels, there isn't much support for the inside of the rim, and with 35 section tires the pot holes have a real advantage Maybe its just something you have to live with.
Boxster Base, 2002 Manual, Black.
LN Single Row Pro IMS retrofit.
Pominoz is offline   Reply With Quote
