I'm right in the middle of doing our first IMS Solution Dual Row, and you should have seen the owner while we were pulling the sump cover and filter looking for metal during the pre install inspection (there was absolutely none). He looked like he was about to have kittens at any moment, and after we pronounced the car suitable to retrofit, he had to go sit down for a bit. He later told me that waiting for our verdict was worse than when his first kid was born.
You have to be careful and do exactly what is right with these engines, and the dammed things will likely run forever. Cut corners, or do something that you know is wrong, and you will end up spending a lot of money for no apparent reason.
