Old 05-11-2016, 02:03 PM   #4
Highrise
The bottoms of your seat brackets don't conform to the floor mounting points in the Boxster. The backs could probably line up, but the fronts are at a slight angle down. You need something like the below to attach the side mounts to, unless you want to drill through the floor.
The Sparco Sprint seats have bottom as well as side mounts. I'll be utilizing the side mounting point to get as low as possible.
Essentially it will be the same setup that Truegearhead from this forum has on his 986 (see below)
I just spoke with TJ over at OG Racing in sterling Virginia (about 20 min from my office) and he gave me a similar response. It looks like I'll need the following parts:
R-9005 Harness Mounting Kit
R-9041 Seat Track Adapter
R-9060 Side Mount Brackets for Sparco Evo/Pro2000, MOMO Super Cup Seats
I wont need the 9044 with sub strap mount since I will be using the factory seat belts, which is why the 9041 track adapter will work, since it seems to accomplish the same goal as the 9044, minus the sub strap.
Highrise is offline   Reply With Quote
