Originally Posted by Jamesp
Sheople, You are warned to stop reading this now. It is not politically correct, you won't like it and it will upset you. Those who govern you or otherwise prey upon you would not approve. It stinks of everyone being responsible for themselves which is completely unacceptable.
For those who stink (particularly you Timco). There is room in the center console for a reasonably sized handgun. This is a Glock .40 Gen 4 with ample room around it. What is needed is a spring loaded door and mechanism to instantly present the gun.
I like this idea also. Some kind of spring loaded door to that section that required a secret slide or something to activate.
Is that the compact model 27? I've got the 23 with a slightly longer barrel.
Replying to the original post: disguising the "pizza oven" storage behind the seats is not a bad idea, unless the thief knew about the Porsche lay out
