Old 05-09-2016, 11:25 AM   #4
rexcramer
1997 Tip, 2018 Macan
rexcramer's Avatar
It depends on how trashed the threads in the pan are. If they are gone, then JayG's suggestion is your only option, IMO also. Try Woody for a replacement.
You will need to pull the pan either way. I would pull the pan and see if you can clean it up with a tap for the pan and a file for the plug. Don't forget a new crush washer. Best of luck.
Please post a pic of both parts.
