Old 05-08-2016, 06:24 PM   #10
Gilles
It is under the intake manifold.
JFP, thanks for the heads up
Two or three weeks ago I was chasing an electrical issue and removed the throttle body with the IPD plennum to have access to the starter motor.
There is a possibility that I pulled too much the hose that connects to the bottom of the plennum,
if this is the same hose that connects to the Purge Valve, perhaps this could be the problem that is causing the leak on the purge valve and triggering the CEL...
Tomorrow after work I will remove the plennum to check for tight connections on the hoses.
Is there a way to check the proper operation of the Purge Valve..?
Thanks again!
Regards
Gilles is offline   Reply With Quote
