Old 05-08-2016, 12:59 PM   #13
reiver
Originally Posted by Akjoe View Post
I believe you can adjust the camber of the window and perhaps improve the seal you're having trouble with. Search through threads here on replacing your window regulator. Not that you need to replace the regulator, but adjusting the window angle and seal are discussed. Might keep the rain out without a full seal replacement.
Yes, the window regulator was replaced right before I bought it, which is where I think the issue started. It's like a shim is missing or something. It's a bit too high in the front and too low in the rear of the window. I was wondering why it smelled a bit moldy in the winter. The water would evaporate quickly in the 3/4 of a year Texas summer and only start stinking when it was the rare cold month.
Right now, the top is stuck closed, so I have to fix that first but this looks to be a great deal for the top:
Porsche Boxster 1997 02 Convertible Soft Top Heated Glass Window Black STF | eBay
I thought about getting an upholstery shop to custom make the seals for much less (and install it).
Thanks!
reiver is offline   Reply With Quote
