Old 05-08-2016, 11:16 AM   #3
BYprodriver
BYprodriver's Avatar
Originally Posted by gpope View Post
I recently had the Boxster in for gearbox fluid change and they noticed a leak from the scavenge/secondary pump. Nothing big but I am driving down to SC/TN area next month and want to square it away. Has anyone done this before? I have searched but couldnt find anything. I found the o-rings on pelican but wasnt sure if it was just as simple as switching those out. Any help would be appreciated.
Geoff
It is just that simple, easiest repair ever. Just remove the 4 outer bolts, do not touch the inner allen bolts, they hold the pump together. The only concern is why is it leaking?? Someone must have had it out before & didn't replace the O-ring.
