Old 05-07-2016, 04:26 PM   #1
HeRoze
Switched fuse or Relay location?
2001 986 S
I'm in the process of installing a solar powered battery maintainer. The goal would be to wire a NC relay to the solar panel output. In order to energize this relay, I would like to tie it to something that was 'on' when the engine was running. I would prefer a location in a box like the fuse-box. Idealy it would be a relay position ready to do what I want (energize a NC relay when running). I do know where the phone jack is under the e-brake and would prefer not to use that (I have other plans for that power...). I've looked through the fuse sections of the schematics and can't tell what I should tap off of, or if there is a spare someplace. Fuse locations D4, D10? Relays BS 3-1, 4-1, 8?
To say it another way, does anyone know of a switched fuse or relay location to rig up the following for a solar battery maintainer. Diagram has some of my guesses. Swirly areas are what I suspect are in the car somewhere, one or the other. 2001 986 S
HeRoze is offline   Reply With Quote
