If it is a Fuel Pump relay, be thankful you got symptoms and a code. When mine went, the only symptoms were engine died and after 10-15 mins, it would start again. Never had a hint it was going until I stopped at a red light, engine died, engine wouldn't turn over until the relay cooled down.
When you engine is running, if you touch the Relay, it will probably be very hot.
Seal Grey
