Old 05-06-2016, 04:48 AM   #1
Cosmo Kramer
Originally Posted by KevinH1990 View Post
Litronics were available in 99, but it looks like yours were retrofitted. I believe the factory litronics came with headlight washers and you don't appear to have those. Of course, the previous owner could have removed the washers. There should be a sticker under the front hood that has all the option codes on the car. You can use that to confirm the options you have.
Do your litronic low beams rotate when you turn on the high beams?
I will check when I pick it up today,didn't notice on the test drive. Great info!
Cosmo Kramer is offline   Reply With Quote
