Old 05-06-2016, 04:06 AM   #10
KevinH1990
KevinH1990's Avatar
Originally Posted by Cosmo Kramer View Post
Thanks I wasn't sure if the 99's came with Litronics as an option or someone adapted it. The clear lenses definitely update the look.
Litronics were available in 99, but it looks like yours were retrofitted. I believe the factory litronics came with headlight washers and you don't appear to have those. Of course, the previous owner could have removed the washers. There should be a sticker under the front hood that has all the option codes on the car. You can use that to confirm the options you have.
Do your litronic low beams rotate when you turn on the high beams?
