Old 05-05-2016, 11:07 AM   #1
m3j0n
The cam cover and cylinder head are machined as a single unit and are a matched set. You cannot mix cam covers and cylinder heads, it simply will not work.
Yes IMS wear out, do a search about engine failures due to the IMS coming apart.
The IMS shaft, and the rest of the engine, are exactly the same in both a Boxster and a Cayman. And $450 is still way too much for a used shaft.
cam cover/cap is not the same as a valve cover. You are referring to a cam cap, which is machined in teh head. The valve covers are not.
OK, $250 for the IMS?
m3j0n is offline   Reply With Quote
