Originally Posted by Gelbster
It is good that ppl are questioning the physics of the sump kits.
TuneRs kit has the 997 swirl/pickup tubes. Originally they had the horizontal baffle in the wrong location.I had quite a debate with the manufacturer on this issue.Eventually they changed their Instructions and heavily redacted the on-line debate - which I am totally O.K. about.The objective was to fix what I claimed was a mistake and they did..
While I agree the horizontal baffle should be on top if you look at my sketch you will see that it does not really matter as long as the vertical baffle fits closely. This is because the end of the baffle plate is too far from the pickup to make a difference that I can see.
