We are in the process of installing a supercharger on a 986 with a 3.4L 996 engine. I know that it is a risk supercharging a 986/996 engine but I think it is worth it
The supercharger is being installed next to the AC compressor on the left upper side of the engine using also an open filter (that will get a heat shield).
New injectors have been installed that can flow up to about 460 HP.
A recirculating blow-off valve is also being installed.
Hopefully the engine will start again today and coming Tuesday it will be strapped on the dyno for further tuning. My aim is 400 HP at the crank (at about 4 PSI Boost).
Now let’s pray together that it all ends well
